FergusonTO35
- 9:57 AM
- Jul 9, 2017
- Boonesborough, KY
Anyone know anything about peep sights? I have a newer Winchester 94 that is drilled and tapped for scope mounts, is there any options that can utilize those holes?
Yep. Williams 5D-94SE or FP-94SE is what you need. The only difference between the two is the 5D lacks the micrometer click adjustments of the pricier FP. Both of them are way cheaper than a respectable scope and mounts though. Now, if it is a Big Bore in .307, .356, 0r .375 you will need the big bore version. There are several different receiver sights out there that can work, however they would require drilling and tapping. My current 94 is a top eject and wears a 5D-94/36 (fits Winchester and Marlin). I'll get an FP or Lyman 66 for it whenever I stumble across a good deal on one.
I've been fooling with rifle sights for years, gimme a holler if you need any advice or would like me to look through my little sight junkyard for you.
