- 6:27 AM
- Dec 29, 2015
- Strong Island NY
Thanks. I had that wrongCase comp is intake close to transfer open.
Run the piston close to tdc and set the pointer to 0. Roll to intake. Check number. Roll on through and back. Check number. Move pointer to the center of those 2. Roll around and check again. If they're the same go to the exhaust and transfers.How do you achieve this?
Sent from my HTC One using Tapatalk
And what is the benefit of this. When you say move pointer, do you mean divide the difference in two and loosen and turn the wheel or physically move the pointer. Also do you still end up with the same numbers as everyone else using the "standard method"?Run the piston close to tdc and set the pointer to 0. Roll to intake. Check number. Roll on through and back. Check number. Move pointer to the center of those 2. Roll around and check again. If they're the same go to the exhaust and transfers.
Why are you switching?I agree, great thread.
It will seem confusing until you get it then it's very simple, I'm a degree guy from tdc but I'm switching to duration.
Wonder how many of us speach Appalachian american here?I'll have to go to the computer to flip it. If You can't understand Appalachian American then I'll have to hire an interpreter
