How to use and read timing degree wheel?
1:37 AM
How do you achieve this?
Sent from my HTC One using Tapatalk
Run the piston close to tdc and set the pointer to 0. Roll to intake. Check number. Roll on through and back. Check number. Move pointer to the center of those 2. Roll around and check again. If they're the same go to the exhaust and transfers.
idiotwithasaw
12:37 AM
Ky
And what is the benefit of this. When you say move pointer, do you mean divide the difference in two and loosen and turn the wheel or physically move the pointer. Also do you still end up with the same numbers as everyone else using the "standard method"?
1:37 AM
Move the pointer. Mine is wire. Same numbers as everyone else.
Mattyo
Youtube speciawist
1:37 AM
Farmington, CT
Ben, I'll work on making a video on timing. I really thought Randy's was excellent on how to get TDC, but I'll try working on one that is more complete. I have off next week, so hopefully I can get to it.
idiotwithasaw
12:37 AM
Ky
I get that there is a lot of technical information to this. Maybe I need to start a second thread about port timing and why you want 100° or close to it exhaust and 70° intake and what does that even mean. Short or long blowdown? What do you look for for more torque/rpm? This is a discussion that could go on and on, and I hope it does. I hope you guys share all you are willing to.
1:37 AM
What is very complicated is that what works for one saw will often not work for another. That is why the builders "book of knowledge" is so valuable.
It is also about angles & size, and more is not always better.
In short, a good builder is easily worth the money, and don't play with your favorite saw if it is your first time!
idiotwithasaw
12:37 AM
Ky
Thank you guys for contributing. I certainly understand that there is way more to getting the full potential our of a saw than just timing, it's another tooth on the gear. The thing is I read all the time builders wanting their intake and exhaust at 70° and 100° respectively. And you don't want your intake duration too long. Why is all this in the most general sense.
idiotwithasaw
12:37 AM
Ky
Im from central Kentucky. Appalachian is my second language. Lol
