How to square file
Hedgerow
1:36 AM
File a chain each way and see for yourself.
1. Every degree matters (including 1/2 of a degree)
2. The Stihl cutter is just about brand new, while the Oregon cutter sits over the rivet ............
3. Tenths of a second seperate culls from contenders ..........
Bottom line, Deets is dead nuts correct, that Stihl cutter would be a grabby muther scratcher, and would need a saw with alot of power to make use of it
Lotsa culls out there..
Get enough power, you can use bout anything..
8:36 AM
Comes here, asks questions like the greenhorn he is, as he gets replies he copies them over to another forum and sells the information as his own!
I have noticed this quite a lot.
8:36 AM
I haven't had the time to track multiple chainsaw forums for months, I am not up to date with other forums.
If You follow more than one chainsaw forum You must have encountered a copycat or two.
OPEForum is my only harbor.
Mkinslow
1:36 AM
Tennessee
I knew I had some of the carlton, mine is skip though, I converted one of them. Wish I could remember where it came from.
