Hedgerow
- 10:02 AM
- Dec 29, 2015
- SW MO
Lotsa culls out there..File a chain each way and see for yourself.
1. Every degree matters (including 1/2 of a degree)
2. The Stihl cutter is just about brand new, while the Oregon cutter sits over the rivet ............
3. Tenths of a second seperate culls from contenders ..........
Bottom line, Deets is dead nuts correct, that Stihl cutter would be a grabby muther scratcher, and would need a saw with alot of power to make use of it
Get enough power, you can use bout anything..
