How to square file
X 66 stang347 X
11:34 PM
Georgia
No attachment. I haven't mounted the wheel yet to see if it will line up. I'll read that post at lunch and check it out.
big t double
You can call me Teddy Eastwood.....
10:34 PM
I doubt it will line up. if I understand correctly...from what I read from the tech bulletin on it....the way the usg attachement works is you lay the head completely sideways...then you swing the lower clamping plate into the wheel. there was a kit at one time that allowed it to work. ive never seen one in person.
A.E.E.llc
Hello myself, its me again
11:34 PM
anywhere
Then it would basically turn it into a swing arm? I agree its not going to work proper without it.
X 66 stang347 X
11:34 PM
Georgia
I figured it might be more to it. Theres guys here that can't sharpen a regular chain right so if I can't find the attachment or swap it back easy I'll have to learn to square file by hand better.
big t double
10:34 PM
I believe so yes...basically. at least from what I can understand from the 1984ish tech note....its kinda hard to read. there is also a diamond dressing attachment that needs to be mounted to redress the wheels.
11:34 PM
I did this one tooth. Does it look like it could work if I play with it some?
That'll cut, but your file was a tiny bit low. And your file should probably point downhill a bit more. It'll cut like crazy like that, but won't last as long
X 66 stang347 X
11:34 PM
Georgia
I left it at 40°. I may try 50 which is max. the other 2 I put on 20 to get the angle closer. I'll try and move the head base a few more ° to get the angle steeper. I'll play around with it some more before I leave and see what happens.
