Sty57
- 1:26 AM
- Jan 6, 2016
- Land of Cheese & Beer
Here's my first attempt......be gentle.
So rotate it down more to the back rivit?Not bad. Need to rotate the file and get a vertical side plate. It won't self feed as good with the tilted back side plate
Interesting device, I was expecting something more similar to the granberg file guide. That's an expensive guide. I guess I'll try free hand. Thanks.Atop is the only option to buy and use.
I have a spare file round guide (File-N-Joint) I might try to modify to hold a square file. Just depends if I can get the proper angles out of it I suppose.
What shape file do you guys suggest for a beginner, single bit, double, bastard, or 3 corner? I'm thinking about trying a 3-corner. That would likely be the only one that might fit into a modified file-N-joint guide. ...
