How to square file
Adirondackstihl
1:15 AM
Upstate NY
Dumb question.....
After working a chain, do you guys give them a bath in something to rinse out the abrasives/filings or you just slap em on and run em?
Cutmaster
12:15 AM
Minnesota
Yea we cut the rakers down .020" only when we need a 36" or longer bar with a big dog saw either a 394/395 or 3120xp.
About 20 years ago I knocked a hole in the oil tank on a 3120xp with a 50" bar felling a huge maple using a square chisel full-skip chain, everything started out fine and then it grabbed like a SOB and bam, bar oil all over, I didn't have a depth gauge with at the time so I guessed long story short I cut a number of rakers down .080" & haven't filed my rakers down past .030" since~!
Sty57
12:15 AM
Land of Cheese & Beer
Teacher I have a question.
I have a few old chains I want to practice on. Cutter length and angles are all over the place on them.
Can I grind them to get them all back to all one size and angle?
What angles should I set the grinder to get them ready to file?
Cutmaster
12:15 AM
Minnesota
Dumb question.....
If I'm in the shop I just blow them off with compressed air, otherwise let 'em fly. I'm not paying my guys to sharpen chains all day! LOL That's why we now use 7/32" Round files, ( 90% of the time ) they are much more forgiving than square chisel chains so a guy can give a round cutter 2 strokes each and be back cutting in just a few minutes. If he's a greenhorn then keeps hitting the dirt with the chain we leave him in the woods as bear food!
Adirondackstihl
1:15 AM
Upstate NY
I was referring to GTG/race chains.
Hedgerow
12:15 AM
Didn't even get it mounted, how bout your extra pokey chain?
Hangin on the 72dl square nail with the others.
I got hedge, locust, mulberry logs in the piles out back. And the only 8x8's I got are oak.
"Not fresh"..
It'll have to wait on some poplar or pine.
J.w Younger
1,000th Member!
12:15 AM
arkansas
This won't be a fast angle but a durable one and maybe easier to learn with because it splits the difference between vertical.
45 down 45 back with a 45 file tilt gives a 15* top plate angle viewed from the top.
Definitive Dave
Piss Rev Mafia Member
1:15 AM
Central Ohio
Ok newbie questions and the answer is probably no.
if a guy was smitten with square ground race chain and wanted the ability to produce decently quick square work chain is there certain model of grinder that would be absolutely best - I mean buy it once and not regret having settled for something else later on type quality? New or used? Would that same grinder be able to do regular lgx round chain as well with other wheels attachments or angles somehow?
Now the biggie would that same grinder be useful in getting a chain part way through the process of becoming a race gtg chain, such that fewer hours of hand work would be required?
And if all this exists in one grinder where can I find it and how much $$ is it likely to set me back.
If I head down this road I want to have my brain around it first.
thanks
Dave
Canadian farm boy
“Normal” people scare me.
1:15 AM
Ontario, Canada
@Definitive Dave I believe the Stihl usg grinder will do both round and square chain. I think there is an special attachment needed to be able to do square. I'm not sure if they are still available to buy new or if you'd have to try and find a used unit.
If my memory is correct @junkman may have one of these grinders and probably knows more about them then I do
