- 2:19 PM
- Oct 21, 2016
- Kansas
Idk..
3000 maybe..??
Hot water too.
Seems like a lot of wood for Southern MO.
Idk..
3000 maybe..??
Hot water too.
He burned into April this year.Seems like a lot of wood for Southern MO.
With those Taylor units it’s either full bore, or nothing.. don’t seem to matter if it’s 40 degrees, or 4 degrees, they seem to eat the same.
We had a hardy and I can remember 15- 21 Rick of wood for a winter. 3000 sq ft, it heated our water as well. Fill it up morning and evening.He burned into April this year.
I got a few neighbors with the Hardy units.We had a hardy and I can remember 15- 21 Rick of wood for a winter. 3000 sq ft, it heated our water as well. Fill it up morning and evening.
I’ve been sorting out and cleaning up in the garage. Put it off for several years but the glut of Echos had tipped the balance. [emoji37]
I stopped counting at sixty ready to run saws. There are ten(ish) on consignment at Jeffs Small Engines. Makes seventy at least. Ten or so projects to boot. [emoji2960]
You guys and your chainsaws. Sheesh! [emoji849]Yeah im in same predicament
Got over 70 runners plus projects and parts saws. Really want to unload a bunch of these but not willing to bend over to do so
Morning fellas! Heat index a killer today!
That is similar to the guess here for now, when, it's 74 and poured rain earlier. While it paused made it out to vehicle, now it's unpaused and I enjoy the rooftop drumming on my minivan. Parked since visual is impaired at LOWE'S free wifi. Used 14 gig of wifi last period.The heat here has been brutal...It is 91° now with 60% humidity for a heat index of 104°. It is supposed to get up to 96° later today.
It was miserable last night at work. I'm hoping its cooler tonight.The heat here has been brutal...It is 91° now with 60% humidity for a heat index of 104°. It is supposed to get up to 96° later today.
The loving power of the Universe said okeedokay, if the radar was accurate about the direction of the cold front w rain washing southerly across Mississippi rather than easterly which is more often.It was miserable last night at work. I'm hoping its cooler tonight.
