cobey
12:21 AM
Pittsburg, kansas
The recoil cover on the 962 finally gave up after catching on fire 3 or 4 years ago along with having 210 PSI of compression.
No fun
Semotony
12:21 AM
DON'T do any action that ends up looking like this;20190423_141337.jpgWas setting rakers on bar, using block of wood to push set part into saw to bring unset depth gauges into range & slipporootie. My 1st aid treatment on site stopped bleeding til it was taken off. Emt at gas station saw it and said glue or stitches. Local ER was $3k only other time when they told me it was a contusion, I told them that it was only a bruise on arrival. No stitches.
VA 80 Miles away less than $20 gas & free but post 3 am racktime.
Could've been much worse if pushing against sharpened side of cutters.
Play safe out there
WKEND LUMBERJAK
12:21 AM
West of Kansas City
DON'T do any action that ends up looking like this;View attachment 178256Was setting rakers on bar, using block of wood to push set part into saw to bring unset depth gauges into range & slipporootie. My 1st aid treatment on site stopped bleeding til it was taken off. Emt at gas station saw it and said glue or stitches. Local ER was $3k only other time when they told me it was a contusion, I told them that it was only a bruise on arrival. No stitches.
Play safe out there
That's a good one.
plcnut
Jesus is LORD
12:21 AM
Mansfield, Missouri
Play safe out there
Ouch!
At least they got you fixed up, and you still have all your digits, and most of your wallet. :)
Semotony
12:21 AM
Ouch!
$20 gas is insignificant. Meeting Rosemary Wensley was worth the pain.;)
On the other side of the spectrum. A VA clinic, 10 miles from my place, won't take out the stitches. They said go make that 3 1/2 hour round trip for that:risas3:. The scissors and tweezers wood have been thrown in the trash if my pocket hadn't gotten in the way. Reading glasses are only a buck around here so a field expedient will prolly happen:eusa_whistle:
countryhog
BTDT
12:21 AM
NW Arkansas
Any of you jonsered guys know what saws share a common o/o switch with the 451E? At least size wise? My 451E has a busted switch and trying to do a workaround. The hole in the case has a ~11/32” hole. Too small to use big box switches without drilling
