67L36Driver
6:17 PM
Morning midlanders!
Once again the rancid dirty 036 started & ran on the first dribble.
I have not had to adjust the H&L mix at all.[emoji15]
Digging thru leftovers for it’s missing parts.
I need to give it ‘the dip’. [emoji6]
6:17 PM
Morning midlanders!
How far away is the mighty Mo to dip it in?
hoskvarna
6:17 PM
Iowa
Same as you buddy. All our snow was melted by rain. Which on a very small scale compared to the west of us. Flooded us out.
Hopefully this warmer temps will get rid of the frost so the moisture will soak in and get rid of the quick sand mud [emoji106]
Sent from Hoskey Hills
Workshop
6:17 PM
Nixa, Mo.
Are the Meteor circlips, piston pin, and needle cage good? Do I need to order OEM? Can I use the old ones?
My experience has been that the piston comes with a new pin, needle cage and circlips. I would use the new ones, myself. I have reused old needle cages and circlips and had good luck. *knocks on wood*.
67L36Driver
6:17 PM
Be very careful mix and match piston, wrist pin and retainer ring. End condition of wrist pin can have chamfer or squared off. Retainer groove in piston can be a different radius to match a large or small wire size of the retainer.
Best to stick with all aftermarket or original parts.
