countryhog
BTDT
12:15 PM
NW Arkansas
I think I’ll stir up some chit on Craigslist.
Post the 245a as the “Texas Chainsaw Massacre” / Leatherface saw for Holloween.
$400 outrageous enuff?
$600 OBO aught to get the low ballers attention. [emoji848]
[emoji48]
It’s an animal with the governor blocked.
What kinda carb? Ive got an orange one and three 306a’s. Need to know bout this govner you speak of
67L36Driver
12:15 PM
Slotted end brass do dad pto side of carb.
Contains a spring loaded ball that unseats at high rpm from the vibrations and lets raw fuel into the airstream thus limiting max speed to safe level for a two piece rod.
Remove it and use a divot of gasket material to seal the bottom of the hole.
Eliminates any interference from the governor.
Some leave it in place and some remove the divot after setting wot fuel mix.
Remember the two piece con rod.
countryhog
BTDT
12:15 PM
NW Arkansas
Ah so. You just using it to set the mix then. Id have to pull it since i dont trust myself to not max out on the throttle. Thanks muchly
Im guessing the tilly carb on the olys may have the same issue
WKEND LUMBERJAK
12:15 PM
West of Kansas City
What have you fixed by removing the Divot.
67L36Driver
12:15 PM
Elam Bend:
We eventually moved to private property on the north border of the wildlife area. Across the Grand River.
Did a lot better there. All the hunters crowding the public ground drove the deer out to us.
[emoji108]
