SteveSS
8:31 AM
Carl - I picked up a hitch hiker last night for the ride home. :)
Homelite410
8:31 AM
Belle Plaine
That would be nice but I don't have access to any at the moment!! Side tensioner on those I assume.....
I finally pried on it til it started moving. They had tightened it too far and had it all jammed up in the front up against the case. They twisted it so hard it broke one of the teeth clean off of the gears. Chain is obviously stretched and needs a link taken out......
Sent from my MotoE2(4G-LTE) using Tapatalk
They side tension like a 372. Much much better tensioner.
Workshop
8:31 AM
Nixa, Mo.
Filter assembly installed.
My son has gotten very good at welding considering we just have a little Harbor Freight flux wire welder. Even on 1/4 inch stuff he gets really good penetration and a pretty bead.
Workshop
8:31 AM
Nixa, Mo.
Splitter is now running again. The lights are mounted, just have to finish wiring the lights and ready to go.
I'm not sure, but the return stroke seems to be a little faster now. Held a full 5 gallons of fluid, too, with 3-4 inches of room left in the tank for expansion and still cover the return inlet. I'm stoked. The real acid test will be Saturday.
