67L36Driver
- 12:37 AM
- Jan 18, 2016
- Missouri
Dunno.
Ideas?
070/090 Tilly HL on evilbay for $12.59 delivered.[emoji108]
Dunno.
Ideas?
I've got a 4cyl all the way to a 6bt cummins!what did you end up with on ur splitter?
Sent from my SAMSUNG-SM-N910A using Tapatalk
My son in law learned something yesterday bout why most guys use ATF in their bale beds..Hydraulics are slooow tonight in the feedin tractor.
Not hydro oil.. Lol
The hard way of course..
Not hydro oil.. Lol
Do they .same a 5-30 hydrolic?My son in law learned something yesterday bout why most guys use ATF in their bale beds..
Not hydro oil.. Lol
No, just wouldn't pump and move. Arms stuck in the up position.Did he take a hydraulic shower?![]()
All that sounds terribly complex for a machine that has 2 functions.Regeneration in hydraulics is where when extending the cylinder, all of the fluid that is being forced out of the cylinder on the rod side of the piston, is added to the oil on the pressure side of the piston. This allows the cylinder to extend at around 3 or more times its normal speed. It does not produce very much force in this mode though. That is why you need a pressure setting to kick it out of regen mode.
Not goodNo, just wouldn't pump and move. Arms stuck in the up position.
Then he broke the plastic hydro tank messing with it.
I had even thought about a hydrostatic variable displacement pump so that you could have the volume and power as needed. That could be really neat!Regeneration in hydraulics is where when extending the cylinder, all of the fluid that is being forced out of the cylinder on the rod side of the piston, is added to the oil on the pressure side of the piston. This allows the cylinder to extend at around 3 or more times its normal speed. It does not produce very much force in this mode though. That is why you need a pressure setting to kick it out of regen mode.
