67L36Driver
6:37 AM
Timing? Flywheel key?
+1. [emoji848]
Actually it isn't a problem keeping a flywheel lined up without the key as many have claimed on this forum.
It's the stress of pull starting that can actually shear the crank and/or the flywheel.
Happened to me twice. Most recently on Farmertec 361.
T.Roller
7:37 AM
Southeast, TN
Hey fellas. Got a question about the husky weedeater I got a few weeks ago. Ran great. Worked it hard for about 2-3 hrs, put it up. Went to get it back out a couple days later and no start. So today new plug, cleaned carb, cleaned flywheel, it either back fires out the muffler or the carb depending on where the throttle position is. Still lean on fuel you think? Coil? I know I got it a touch on the warm side. Oh and I removed the spark screen as well and it is clean. Carb screws are 1.5 rnds out. Got any ideas? Thnks.
Coil
Hedgerow
6:37 AM
If the piston looks ok,
Suspect the coil.
hoskvarna
6:37 AM
Iowa
Hey Mark..
JD 5085M series...
Are they really as bad as I've read??
You heard anything?
Have not heard of anything but I don't follow the JD stuff much.
I'll ask my nephew he just graduated from diesel mechanic school.
Sent from Hoskvarna Hills
Hedgerow
6:37 AM
Backfires usually mean coil saying go, when it ain't supposed to..
You can take it from there no doubt.
Locust Cutter
Air Force Redneck
6:37 AM
KS
Well, it looks like 2 new exhaust manifolds and a new upgraded set of up pipes for the 7.3 + labor (to fix the leaks killing my drive pressure/air flow and making for hot EGTs) is going to be between $1-1.7K depending on how many bolts break off and require drilling/tapping prior to replacement... This F.or O.bnoxiously R.ich D.rivers is turning into a hell of a money pit...
6:37 AM
Dam thats not cool.
moparnut88
7:37 AM
US
+1. [emoji848]
Well when I went to pull start it it took more force than usual. Then it went to normal again after 2-3 pulls. But I think it was partially hydrolocked, but not sure how it could have been it had just been sitting.
67L36Driver
6:37 AM
So, no one calling dibbs on the yummy projects I drug home?
The garage is full so I stored some in the trunk of the Corvair.[emoji37][emoji90]
6:37 AM
Morning Gentlemen!
Was it on this thread I saw someone soak a bar in a vinegar mix to remove rust?
MG2186
6:37 AM
Summer,IA
Why are you needing to replace the manifolds? We just surface them. You can buy a gasket set with new bolts off eBay. I did mine for less than $150. Broken bolts aren't bad to get out, just weld a washer then a nut to the washer of the broken bolt, they'll come right out
Workshop
6:37 AM
Nixa, Mo.
They all look interesting, for sure.
The Massey Ferguson looks to be an ash trey saw. Not many of those around.
67L36Driver
6:37 AM
Morning Carl
If you need somewhere to dump the MF I would put it on the shelf.
Noted!
Not only Allis Chalmers but MF collector you are as well.
I'm sure it is a 31cc ripper.[emoji6]
