Douglas Ostrander
11:12 PM
Waukee Iowa next to I80
#1 reason for firewood. Campfire by the lake.
Sent from my SM-N910R4 using Tapatalk
67L36Driver
11:12 PM
Got any 72 dl .050 husky chain in there?
Don't know yet. Just sorted the obvious LP into a separate box.
Need to figure out a chain rack.
When you hang 3/8" loops from a horizontal rod 1/2"-1" dia., it gets easy to seperatre the lengths. Even the 70 & 72 driver stand out from each other.
Hedgerow
11:12 PM
Cut an access hole in the top of the tank and replaced the welded nipple with an inner and outer threaded plate and big rubber washers to sandwich the tank steel with.
Started and ran it last night and this morning.
No leaky..
Today will be the 2-3 hour run test.
67L36Driver
11:12 PM
Building a chain loop gauge. 1x3 x 4 foot (ish) long. 1/2" dowel rod in carefull drilled hole (drill press).
Using new, or nearly so, loops of known driver count marked where centerline of rivets end up.
If the one side works out, I'll do the other for 3/8 LP. And, make another for .325" & .404".
