sawnami
10:29 AM
Springfield
Pipe looks like some kid of beer spigot.
You going to have to take down the rest of the tree?
It's a goped expansion chamber as Cobey said.
It will eventually have to come down. It wouldn't be fun as it's around 60" DBH and 80 feet tall with houses that it can "reach out and touch". [emoji16]
Sent from my SM-N910V using Tapatalk
moparnut88
10:29 AM
US
Sounds like a tree that'll have to be taken down from the top first. It would be fun though! I finally got all my climbing gear! But all my big trees I was gonna use them on have already came down due to weather.
67L36Driver
9:29 AM
Been rinsing water out of the Oly's fuel tank. Such is the downside of 'the dip'.
Fuel line came out of the bulkhead.
Should have replaced the line first.
But, it's a lot cleaner than it was. Starter was so gooed up it barely worked.
countryhog
BTDT
9:29 AM
NW Arkansas
Got a newbie question. Been so busy with other things i havent worked on saws in a good while so ive literally forgotten stuff
Got around to cutting with one of the frankenolys i put tother last fall. Got it tuned in to where i runs well (kind of, havent done any heavy cutting yet). Problem is that when i let off the throttle it takes really long time to idle down. Adjusted the low side little leaner to where i still have good throttle response. Thinking the needle in the carb may need adjusting but im at a loss which way to adjust it.
Someine take mercy on an OF and give me a hint
cobey
9:29 AM
Pittsburg, kansas
I got called to the church earlier,
A lady said water was coming "out
Of the bicks" on the back side.
When I got there there, a sink
Hole was open in the alley about 40 feet
Away water was pouring out of the
Foundation, the main supply line is broken under tons of asphalt and concrete. .... the only option is to go
Threw the other side of the building.
Gonna try to find an engineer to help
Us... what a mess
moparnut88
10:29 AM
US
Us... what a mess
Boy that does sound like a mess! We'll put you guys on the prayer list this morning! Hopefully it will be repairable!
