Ethan Hamby
- 2:29 AM
- Nov 25, 2016
- Calico Rock, Arkansas
Simple way to make it where I don't have to screw the nuts down 2 inches of thread
Keep the pics coming Ethan so I can learn.Simple way to make it where I don't have to screw the nuts down 2 inches of thread
Academy?Plus I needed something to do while I'm waiting on my new carb... Hopefully it gets here before I leave for Academy Monday
If you buy these, you'll save yourself a lot of trouble. And the seller is a member of our forum. Great guy. @Definitive DaveI wonder if the tape will seal like I think it will... Lol. It should be enough to hold a few psi for a pressure test. Muffler side I'll probably cut a piece of aluminum plate and put some inner tube on the back
I've used Gorilla Tape alone. Just stick a piece on, poke a couple holes through it and bolt it back together.I wonder if the tape will seal like I think it will... Lol. It should be enough to hold a few psi for a pressure test. Muffler side I'll probably cut a piece of aluminum plate and put some inner tube on the back
Pressurize the fuel inlet side of the carb. It should hold 5PSI. If not, you've got a needle and seat problem.I don't even think it has a crankcase leak because I saw the carb visibly dumping fuel randomly when the saw was off lol but I'm going to test it just because y'all keep saying to
I stripped the huztl carb and have an OEM tillotson on the wayPressurize the fuel inlet side of the carb. It should hold 5PSI. If not, you've got a needle and seat problem.
Sent from my SM-T900 using Tapatalk
