Ethan Hamby
- 2:38 PM
- Nov 25, 2016
- Calico Rock, Arkansas
My experience with box saws is this; if the screw fits, that just may be the right one. If you have some left over, you either did something right or the factory tossed in a few extra just to mess with ya.I have a 25 mm set of av screws and a 22.5 mm set.... The 22.5mm have a smaller shoulder... Which is correct?
I would hope the choke is normally open.Choke butterfly was stuck open. That's why. Done for the night
you mean th black screen thing?I've had that happen a couple of times. Always turned out to be the filter base wasn't allowing the return spring to operate almost like the hole wasn't big enough. I was able to play around with it by loosening the nuts and finding out which way would allow it to freely travel and didn't have to modify anything....it sounds good though! Congrats!!!!!![emoji41]
Its chilly this morning![]()
Sent from my N9516 using Tapatalk
