Only the Tony
12:47 PM
Waiting for it to go above freezing to get some things done. Dentist was a bust, white coat syndrome kicked in and blood pressure went up too high. Try again in a month or so. Went for checkup immediately after leaving the dentist and pressure had dropped 20 points on upper and 15 on lower, already back in normal range by the time I got home and ate a little breakfast.
Only the Tony
12:47 PM
20/42 & clear today.
Had the PUD move the meter from the house to a pole this morning.
Decided it'd be the best way to get power to each of the buildings as it more or less centrally located.
How many amps are you running to each building? If I had known you were doing this I have some aluminum service wire in the barn you could have taken with you on Saturday.
