- 12:04 PM
- Apr 13, 2020
- 5543X, 5644X
Good morning folks
Every time my wife’s car needs something she starts chirping about wanting a new car.Wednesday I had 4 new tires a battery and a lube oil filter on the escape. That only cost almost $1500.
Stayed up late or get an emergency repair call?Happy Friday!
Let’s get it done.
It’s likely either the valve stem or a slow leak around the bead. I have had some mystery leaks over the years as well.View attachment 448711
Got a tire going flat within less than a week on the truck and this is all I can find on it after three dousings with soapy water and this is not leaking. Time to get some tires anyway, but I am wondering which will be cheaper, my tires or fixing your truck.
Neighbors dog comes over most nights and sets off the camera on the front porch. This one attacked my dog few years back and they said that it never comes over here. One night when they are gone and it wanders over I will catch it to remedy the issue. Luckily I live on a highway so I guess it just got "hit" crossing the road.
And I’m ready to clean some white bass..@Sawdust Man needs to figure out the run on Bull Shoals with his boy as well. They will still need the length of days and water temperature to make the spawning run. Hope it is a good year for it, time will tell. I'm ready to fix breakfast on a creek bank somewhere.
Sunny 50*, windy & muddy here.Turned cold and windy.....pretty much a miserable mud hole outside.
Replaced stem twice to make sure in case the first had some corrosion on the wheel I missed. Broke down the bead three time and finally greased it up to make sure it sealed. Needed some new tread anyways so $1000 later its done.It’s likely either the valve stem or a slow leak around the bead. I have had some mystery leaks over the years as well.
and crappie and bass and walleye and perch and spoonbill and.....And I’m ready to clean some white bass..
As soon as the frost line is out of the ground, the water will move as it should.Turned cold and windy.....pretty much a miserable mud hole outside.
I’m just ready for some fish..Replaced stem twice to make sure in case the first had some corrosion on the wheel I missed. Broke down the bead three time and finally greased it up to make sure it sealed. Needed some new tread anyways so $1000 later its done.
I will help..........................................eat itAnd I’m ready to clean some white bass..
It's been weekend since June 2000 4 me, while it's 33° they alleged when I looked a few moments agoWelcome to the weekend folks, well at least for somes of us!
