- 11:52 AM
- Jan 22, 2022
- MO USA
That's a rather purdy stack of lumber. Do you have plans for it or do you sell it off?Mornin.
32/72 and sunny, is the idea.
Cut up most of the "free" walnut logs yesterday.View attachment 410139View attachment 410140View attachment 410143
No real plans.That's a rather purdy stack of lumber. Do you have plans for it or do you sell it off?
I was like that back when I was overly time constrained. However, now that I have a few additional minutes to enjoy stuff I like doing, another CAD type issue developed. Started with small batch roasted beans chopped with a cheap spice grinder, and added a mid-grade conical burr grinder to get even sized small sand sized grains of ground coffee for best flavor. To fine of a grind with powdery residue make the brewed coffee rather bitter IMO. Now if you enjoy a cup of Turkish coffee that's your prerogative.I know next to nothing about coffee. But I do know this.
I get it from the grocery store.
We use only fresh home ground coffee.....I don't like coffee enough to drink pre-ground stuff.I was like that back when I was overly time constrained. However, now that I have a few additional minutes to enjoy stuff I like doing, another CAD type issue developed. Started with small batch roasted beans chopped with a cheap spice grinder, and added a mid-grade conical burr grinder to get even sized small sand sized grains of ground coffee for best flavor. To fine of a grind with powdery residue make the brewed coffee rather bitter IMO. Now if you enjoy a cup of Turkish coffee that's your prerogative.
Currently we're enjoying Mt Comfort Peru (single origin), it's "nearly" as smooth as blue mountain or kona, but at a small fraction of the price. We get this at Costco, but they also ship from the factory, and with a large enuf order shipping fees are waived.I noticed that also.
I used to think that the finer the grind the better the coffee but the coffee always seemed bitter. A coarser grind seems to be best for flavor & no bitterness.
I went from drinking 2-3 pots a day for several years to no coffee at all for about 3 years. Now it’s usually 2 cups in the morning.
It’s usually just Maxwell House in the mornings here but I will occasionally get beans from Africa, Indonesia & some Jamacian Blue.
For the "not" oily coffee's, I've found that the max. extraction has been with a consistence of grind that feels slightly gritty between your fingers, somewhat smaller than typical sand. I'm also using a "gold" metal coffee filter. We find that the paper filters add there own slight chemical taste, that we'd rather do without.We use only fresh home ground coffee.....I don't like coffee enough to drink pre-ground stuff.
I know getting the grind right affects the flavor but haven't really made a science out of that yet.
We didn’t make that at WireCo. Traction steel wire rope. Too much liability or so I was told.View attachment 409787View attachment 409788Just another day at work.
This is an old freight with dual drum drives.
I use lacquer thinner. The nasty strong chit for removing paint and cleaning brushes.Dug my Mac 795 with a stow cut off attachment out. Tring to get her going. It has a tank full of varnish and I need a fuel line and filter. What are you guys using to get the varnish out? And where is a good source for the fuel line and filter? I didn’t see one on the bay.
The liability along with the addition of the hemp rope would change the construction process vs normal I would guess?We didn’t make that at WireCo. Traction steel wire rope. Too much liability or so I was told.![]()
You got some gooders there.
Lotta btu's there.
Nice!View attachment 410217
I took a day off from working. Back at it early tomorrow morning. Calving season.
I’ve got some of that. I’ll try that. It was an auction buy tring to get her going. Where can I find a fuel line for it? Or is everyone swapping over to Tygon or something standard?I use lacquer thinner. The nasty strong chit for removing paint and cleaning brushes.
You may have collateral damage.
