nbbt
5:51 AM
5543X, 5644X
Sawdust Man
Manufacturer of Sawdust
5:51 AM
MO USA
That's a rather purdy stack of lumber. Do you have plans for it or do you sell it off?
No real plans.
Hopefully I can sell most of it.
Eventually I'm planning to get to finishing our house, so I'll need material for trim, cabinets, and maybe some paneling.
nbbt
5:51 AM
5543X, 5644X
I know next to nothing about coffee. But I do know this.
I get it from the grocery store.
I was like that back when I was overly time constrained. However, now that I have a few additional minutes to enjoy stuff I like doing, another CAD type issue developed. Started with small batch roasted beans chopped with a cheap spice grinder, and added a mid-grade conical burr grinder to get even sized small sand sized grains of ground coffee for best flavor. To fine of a grind with powdery residue make the brewed coffee rather bitter IMO. Now if you enjoy a cup of Turkish coffee that's your prerogative.
JimBear
5:51 AM
IA
I noticed that also.
I used to think that the finer the grind the better the coffee but the coffee always seemed bitter. A coarser grind seems to be best for flavor & no bitterness.
I went from drinking 2-3 pots a day for several years to no coffee at all for about 3 years. Now it’s usually 2 cups in the morning.
It’s usually just Maxwell House in the mornings here but I will occasionally get beans from Africa, Indonesia & some Jamacian Blue.
Sawdust Man
5:51 AM
MO USA
We use only fresh home ground coffee.....I don't like coffee enough to drink pre-ground stuff.
I know getting the grind right affects the flavor but haven't really made a science out of that yet.
nbbt
5:51 AM
5543X, 5644X
Currently we're enjoying Mt Comfort Peru (single origin), it's "nearly" as smooth as blue mountain or kona, but at a small fraction of the price. We get this at Costco, but they also ship from the factory, and with a large enuf order shipping fees are waived.
For the "not" oily coffee's, I've found that the max. extraction has been with a consistence of grind that feels slightly gritty between your fingers, somewhat smaller than typical sand. I'm also using a "gold" metal coffee filter. We find that the paper filters add there own slight chemical taste, that we'd rather do without.
67L36Driver
5:51 AM
Dug my Mac 795 with a stow cut off attachment out. Tring to get her going. It has a tank full of varnish and I need a fuel line and filter. What are you guys using to get the varnish out? And where is a good source for the fuel line and filter? I didn’t see one on the bay.
I use lacquer thinner. The nasty strong chit for removing paint and cleaning brushes.
You may have collateral damage.
Jetmd
5:51 AM
Smithville, MO..Born in Iowa by the grace of God
We didn’t make that at WireCo. Traction steel wire rope. Too much liability or so I was told. 🤔
The liability along with the addition of the hemp rope would change the construction process vs normal I would guess?
Sawdust Man
5:51 AM
MO USA
Sawdust Man
5:51 AM
MO USA
This afternoon the boys and I stacked most of the lumber I've cut in the last three days.
White oak, black walnut, hickory, ash, & cherry.
Mostly 1" but there's a bit of 2" & 2.25" material.
12' on the bottom, then 10's and 8's on top.
For reference, Sam is about 5' 9"
moparnut88
6:51 AM
US
I’ve got some of that. I’ll try that. It was an auction buy tring to get her going. Where can I find a fuel line for it? Or is everyone swapping over to Tygon or something standard?
