Hinerman
11:45 AM
NE OK
That skid steer would pretzel that thing in 10 minutes tops...
Agreed, hence the word, similar. No pretzeling with a heavy duty claw and forks. I would like to see it twist heavy duty forks. With one claw you don't have the twisting force you get with 2, imo
Maybe the forks I am imagining don't exist. Not talking about pallet forks.
Hinerman
11:45 AM
NE OK
I have this one but with the single top grapple instead of the two like this one. I’ve beat the holy hell out of it and it still looks great. No bends/tweaks anywhere on it. Can’t say enough good things about it.
Exactly, one claw equals less twisting forces.
Hinerman
11:45 AM
NE OK
JimBear
11:45 AM
IA
Probably the closest thing to what you are talking about Thomas.
https://clfab.com/products/stump-bucket/
Hinerman
11:45 AM
NE OK
More like this, except heavier duty. Heavier forks and heavier claw:
67L36Driver
11:45 AM
Thirty degrees cooler today than yesterday. [emoji2960]
Hunter’s MS201t #3 chit the bed.
Just got it running and it stopped sudden. [emoji90]
Peering in thru the spark plug hole it looks like a wrist pin retainer wasn’t seated properly. [emoji21]
Hedgerow
11:45 AM
Who set it?
No way it was you Carl...
67L36Driver
11:45 AM
Who set it?
I’m the one to blame. [emoji19]
It didn’t seem right but resisted against the pin when I tapped on it (the wrist pin).
Meteor piston kit lacked retainers due to some oversight. So, I used others.
Likely squeezed it too much and lost tension.
Edit:
Both wrist pin retainers were in place and intact. [emoji2955]
It had to be some tramp material hiding behind the crank or in the intake tract. Can’t find anything. [emoji90]
Hedgerow
11:45 AM
You don't need tiktok to view this.
https://vm.tiktok.com/TTPdhk3KoM/
Good way to cut yer fingernails..
And everything else off..
We made ours so the hands have to hold the 2 levers engaged or she goes right back up..
And there are STILL a couple people who I have banned from it's use..
11:45 AM
All of ours have the dual triggers and light curtains and our shop is sketchy AF.
