Hedgerow
2:41 PM
A big mulberry slab
Sent from my SM-G975U1 using Tapatalk
Good ole Mulberry..
Never thought to make a slab out of one..
awol
2:41 PM
Cabool, MO.
Good afternoon everyone, this is Mrs. Awol. I thought I would share a link for the upcoming auction. We appreciate all your kind thoughts and prayers. We did not try to list every single chainsaw that will be selling, as there are just way to many. The auctioin will be on February 26, 2022 not sure why the link is saying December 1st.
https://www.kellyauctionco.com/december-1st
Semotony
2:41 PM
May I contribute some more saws needing fix? One's a gear drive, one 2 man mall I think. Wanna help if I may
Semotony
2:41 PM
That is appreciated very much.
Glad to provide. James smile when I told him " if the saw gets stuck, leave it. We can always get another saw but we aren't getting another you!" Hedgerow reduced to firewood at Matt's sister's place
Statement goes for each of us
Oh yeah at the moments before, Kyle was dangling a log over head
BrettL
2:41 PM
Wichita KS
Good afternoon y'all. Any of you have experience with the Redmax 3500t or its Jonsered counterpart? I found a new Redmax and used Jonsered at a pawn shop, 370 for the pair. I feel good about the buy. I've had Zenoha engines in rc planes and loved them, very dependable.
I saw a lot
2:41 PM
Omaha, NE.
Picked up this MS460 this morning and seems like it has good compression. Put some mix in it after leaving and it did start but reving instead of idling. @Wood Doctor is going to check it out. Under $200 so hope it works out as my plan is to give it Lefty to replace his 044 that burned up in the fire.
Workshop
2:41 PM
Nixa, Mo.
Got a question for all the scope gurus.
This is concerning my Ruger air rifle. It came with a Ruger 4x34 scope that I changed out to a Weaver 3-9x40 because it had a brighter picture. Started the sighting process at 10 yards using a 55 gallon barrel as the target. Shot a marker impact to use as a target then took 5 more shots. All about 1 inch low and a half inch to the right. Scope says 1 click is 1/4 inch at 100 yards. Did one click up and reshot. No real change. 2nd-4th shots I adjusted 1 click. Still no change. So I spun the adjustment 10 clicks. Still no change.
Changed back to the Ruger scope and got the same results. Then I just removed the scope and used the iron sights. It was better, about an inch low but straight under and was able to adjust it to where I was 1/4 inch off target 5 shots in a row. 2 bad scopes? Or am I missing something?
:confused::mad:
MACHINE
3:41 PM
Broken Bow, Oklahoma
:confused::mad:
Use a scope rated for air rifle
Hedgerow
2:41 PM
:confused::mad:
Welcome to air rifle world...
If the scope is not an “air rifle” scope.. all bets are off..
But don’t be dismayed when you find out the air rifle shoots damn poor groups... cuz they are famous for that...
The scope is mounted on the action and the pellet is loaded into a barrel not attached in any meaningful way, to the action...
But the iron sights should be on the barrel, so they should be a little better.
Hedgerow
2:41 PM
Levi has a Benjamin .22 air rifle..
Jeremy Shockey special...
Lol...
If I had that thing, I’d throw the mf’ing thing in the dumpster and be done with it.
