Cat 525
5:54 PM
Central Kansas
What do you guys think it’s worth? 4020 side console. Been setting for many years. Prlly 7-12yrs.
You buying or selling? A ,4230 in so so shape with cab brought 17,000 at an auction here Saturday!
JimBear
5:54 PM
IA
Those generally sell for more than the dash consoles. Diesel or gas? I think they made gassers in the 4020’s but I maybe mistaken. It’s got a lot it weights hanging on the front end. I’ve never seen one with that many from weights.
I am thinking $10k - $12k will be asking price.
moparnut88
6:54 PM
US
It’s diesel
sawnami
6:54 PM
Springfield
Its junk wood as far as I’m concerned
Yes it burns but quick and not much btu’s
Not worth the time
Sent from Hoskey hilltop
Yeah, it doesn't appear to be a good heating wood.
I picked it up for Tammi's and my wood projects. I've also got a neighbor with an amazing wood shop that likes to turn bowls.
Here's a spalted hackberry bowl that he turned from a tree that I cut down in my yard.
Sent from my SM-A716U using Tapatalk
hoskvarna
5:54 PM
Iowa
Beautiful work
Hedgerow
5:54 PM
It’s amazing how that locks a saw up. I thought the piston got stuck sideways it was so tight. What saw? Is that the 064? What kind of wood?
Bore cutting a juicy hackberry tree.
Using 24” of the 28” bar..
My fault.. but boy did it stick surprisingly quick.
064.
Hedgerow
5:54 PM
I think it’ll run. Gonna need serviced at minimum. My concern is seals being dried up.
A straight, good running 4020 will bring 12 grand easy enough, sometimes more, but after sitting that long, it’s an unknown.. so assume you gonna have to go completely through it. I hate machines that been sitting that long. Cuz ya just never know.
Louie B
5:54 PM
MS
With that many weights on the front it had something heavy on the three-point would be my guess. A heavy drill or planter probably. Check the draft control shaft and seals and the bottom for wear. Common problem on the deers.
moparnut88
6:54 PM
US
Yes came from a local farmer. So that makes sense.
Hinerman
5:54 PM
NE OK
064.
I was cutting hackberry last year around this time. I had 3 bar tips locked up when I left.
When I stuck the clutch sprocket it happened instantly when I hit the throttle coming out of a cut. I thought the piston locked up
Fishnuts2
5:54 PM
SE MN
I think the console models were made from 1968-1972. You could get Diesel, gas, or LP engines.
I still think that Deere would be afraid of how many 4020’s they would sell if they were to produce them again!
Semotony
5:54 PM
But a MS170/180 is only worth $120 at best. Poulan 3314 is $119.95 at Wally World, new.
$65 is all I'd pay at auction for an 017, the guy used 170 more, lil screwdriver confused operator? Estate auction
Had same thought on a Grand Marquis yesterday.. Auctioneer said it'd been sitting a couple years with nearly full tank!
I'm still in market for cavalier replacement lol
67L36Driver
5:54 PM
Somewhere in this [emoji2959][emoji2959][emoji2959][emoji2959] garage is a zip lock baggie with all my 9/16” rivets and tie straps.
Still looking. [emoji90]
Edit: Found ‘em. Under a pile of books.
[emoji3060]
Workshop
5:54 PM
Nixa, Mo.
[emoji3060]
Need to get rid of that old Ford and old Chevy.
Gain some room.
:couch:
