67L36Driver
2:19 AM
Looking for a cylinder cover for 2065 jonsered,
Or will some Husqvarna fit it??
Sent from my SM-G955U using Tapatalk
I once had a 2171 that needed a top cover. Finally bit the bullet and put on the equivalent Husky top and recoil so i could move it along.
It was some ugly. [emoji90] but it ripped.
Husky 365 IIRC.
MACHINE
3:19 AM
Broken Bow, Oklahoma
Husky 365 IIRC.
He doesn't care as long as it fits
Hedgerow
2:19 AM
Kenneth would know for sure, but I think the 2065 was an actual jonsered design.. not sure if it shared any 365 husky bits.
2:19 AM
2065 is op 365 if I remember correctly and the 2165 is the cp like the 365. And a 2171 cover would fit too and have easier access to the AF.
Workshop
2:19 AM
Nixa, Mo.
Good Morning everybody...
Anybody heard from Workshop? He hasn't posted in almost a month!!!
Still here. Mostly just busy with the postage stamp designing stuff and planning so I've just been lurking here. When I'm not down there I've been busy in the evening getting projects ready to go down there.
67L36Driver
2:19 AM
I have one here.
One will have to use the Husky top cover and recoil starter due to the ‘styling’ difference.
Otherwise the J-red 2065 is just a 365 in red.
I watched evilbay two months for an actual Jonsered top cover. [emoji90]
BrettL
2:19 AM
Wichita KS
Good afternoon y'all. Working on a ms171. Little saw has compression, spark and seems to be getting fuel. What a little turd!
Fishnuts2
2:19 AM
SE MN
Those projects are perpetual, but that’s ok. You’re just too handy and can do them Steve!
I got my other knee done today, and hopefully in 3 weeks I can ride my ATV across the ice to the cabin. Plan is to haul supplies up the hill from the lake as I’m tired of climbing that hill. If that doesn’t work, I’ll tie the two canoes together and load the ATV on them. Tow it across the lake like I did with all the large lumber and doors. Still 3 ft. of ice so I have a little time yet!
2:19 AM
OP...
CP...
Not following..
Open port
Closed port.
Some of the early 48mm jugs were open port units and the intake boot bolted to it vs using a slip over design with a clamp.
But I am no jonseredologist either..
I just know Kenneth's 2094 aint like any husky I know of in appearance..
The 2094 and 2095 where a Partner design before mother Husqvarna shut that down.
The 2094/95 only share a piston with their Husqvarna brethren.
But over all if I had a 2065 I'd look for the the newer 2171 or possibly 2171 top covers that are 2 peice.
Workshop
2:19 AM
Nixa, Mo.
Evening everybody.
Wife and I got our Rabies shot last Friday.
Just now starting to feel better. It wasn't bad though, just felt icky. I hear the second shot is the one that's rough.
But I guess it really depends on the individual.
Or I'm just a pansy.
WKEND LUMBERJAK
2:19 AM
West of Kansas City
Yes that would be correct.
That is a fact . I should run it more but I don't get into big enough trees that often. May have to put a 24 on it . But it is still heavy.
MACHINE
3:19 AM
Gut muffler, change carb to fully adjustable, add a little cheap time to it , it helps a bunch , check seals , they are bad to leak on that model
Here's one a did a few weeks ago, it's much better, i put new motor in it for 42 bucks Amazon LOL
hoskvarna
2:19 AM
Iowa
Hope it heals well for you [emoji106]
Sent from Hoskey hilltop
Fishnuts2
2:19 AM
SE MN
I carried my walker into PT at 10 days for the first one. This one seems to off to a good start.
People come from all over the Country for this surgeon, I’m very thankful to get in here.
