Locust Cutter
Air Force Redneck
12:43 AM
KS
Might I suggest a walk in cooler that can maintain 34-35 degrees with ease?
Another client of Shalie's business has an HVAC business. He recently changed out walk in cooler for the KFC in Derby KS. We may be getting a 10x12 for a nominal sum, that's older but in perfect condition...
67L36Driver
12:43 AM
Morning midlanders!
I got Echo 590 #1 running. After a short blast to clear out the assembly lube we have 120. A marginal improvement over the original 110. [emoji57]
This is in a really shabby cylinder.
Not snagged the extra ring.[emoji1696]
Give it a tank of fast idle and check comp again.
Lurch
12:43 AM
Long Lane, MO
I am looking forward to building a butcher area in the building that Shalie and I are going to build by our house... I figure a darn good grinder, a used meat bandsaw, and a slicer, and we're in business, unless we do it traditionally with knives...
Don't forget lots of work space. Stainless tables or butcher block tops. Need to consider packaging too.
Not cheap to get into but mostly up front cost for equipment.
12:43 AM
I bet one could find some SS prep tables on the cheap from some restaurants closing down.
Hedgerow
12:43 AM
Morning midlanders!
How much squish clearance?
Something tells me more than ideal?
67L36Driver
12:43 AM
IDK and really don’t care as it won’t matter to Hunter’s Lawn care.
Now pumps 140 cold. One for the win column.[emoji3060]
Sit there and idle all day and cuts well enuf.
My two ring theory for somewhat scored cylinders is proved.
67L36Driver
12:43 AM
MACHINE
1:43 AM
Broken Bow, Oklahoma
For sale 1970 and 1973 cub cadet both run good decks disk and cultivator and tiller attachment
1200 for everything
Sent from my SM-G955U using Tapatalk
