MACHINE
12:55 PM
Broken Bow, Oklahoma
Nice soft night
Sent from my SM-G955U using Tapatalk
MACHINE
12:55 PM
Question on a Sthil MS440 ,
The cylinder is damaged and clutch side bearing is VERY bad , nearly 1/8 inch of play .
Found what damaged saw , the air cleaner was leaking on bottom...
Question, how much does it cost for total rebuild if the case is not damaged???
We're talking labor and parts .
I figured $300 plus at best , saw not really
Worth it IMHO .
Saw is very clean though
11:55 AM
Worth it IMHO .
What kind of cyclinder damage?
Semotony
11:55 AM
Worth it IMHO .
I've got a big bore 460 p&c that may fit! A lil bit of exhaust porting might make it more interesting if; ya know, open up the sides no more than 70% of bore diameter maybe file the piston edge @ exhaust to match the curve of the port for the largest opening at highest pressure IIRC oh wait! How much is shipping to 63650? lol
67L36Driver
11:55 AM
Hmmmmmm. [emoji848]
A true candidate for a Farmertec MS440 parts kit if there ever was one maybe. Use the serviceable OEM and fill in with parts from the box. [emoji6]
The 460 I completed last month works great. [emoji106]. (If you can pull it over.[emoji3061])
MACHINE
12:55 PM
Hmmmmmm. [emoji848]
How
Much would you charge customer?
67L36Driver
11:55 AM
Case is most likely spun...
If so, salvage parts and *s-word can it.
Yes, it all hinges on the case being good to go.
Could easily be the flywheel side plastic ball separator in the bearing. I’ve come across a few melted/gone.
