cobey
- 8:08 PM
- Jan 16, 2016
- Pittsburg, kansas
Fell off a shelf at a saw shopHow'd it break? Dropped off a truck?
Fell off the bench, broke the chain break handle mount.How'd it break? Dropped off a truck?
Should u heat the case halvesFell off the bench, broke the chain break handle mount.
Should i...Should u heat the case halves
And freeze the crankshaft?
I do. Bearings on crank first, freeze crank, heat bearings in oil. Then freeze crank and bearings and drop into warm case.Should i...![]()
My bearings are already in the caseI do. Bearings on crank first, freeze crank, heat bearings in oil. Then freeze crank and bearings and drop into warm case.
Ya that's how the case cameAre the seals in?
ThanksNo worries Coby. Put the crank in the ice maker and the cases in the oven at 275-300 degrees.
Polish the crank with 400 or 600 wet or dry. A thin coat of grease also.
Twenty minutes is all it takes.
Wear your oven mitts.
Will the heat hurt the seals?No worries Coby. Put the crank in the ice maker and the cases in the oven at 275-300 degrees.
Saws get pretty hot on there own .Will the heat hurt the seals?
