Douglas Ostrander
- 5:20 AM
- Dec 4, 2015
- Waukee Iowa next to I80
Yes the mill is new. Still modding the mill to what I am needing. I ended up getting the Mikron Set works. Still tunning the programming. Then add a winch to assist in turning large tree trunks. Then some fine tunning of the the board drag back. Which means a complete redo of the dragging arms. Pour plasma cutting which caused to much bevel (not a square cut). Max depth of cut is only 9 inches as is. Engineers can't leave equipment as is. I do like the four post system with solid band wheels. Plus the drive belt is completely separated from the blade side.I'm guessing you got a new mill?
Those Cooks mills look like real beasts, I'm interested to hear your impressions.
