sawnami
- 8:11 AM
- Jan 20, 2016
- Springfield
Good afternoon!
Watching grass and weeds literally dry up and blow away leaving bare ground in several spots in the yard. The blue-tailed skinks must be OK with this weather as they seem to be everywhere you look.
I picked up a Homelite C-5G and swapped another planetary gear drive onto a C-91. You can pull up on them buried in a cut as hard as you can and they won't stall. You don't want to lay your arm across the cooling fins on the drive housing as you may end up with some lines branded onto your arm.[emoji51] There's a lot going on inside that little housing.
Sent from my LE2117 using Tapatalk
