Jetmd
- 3:07 AM
- Jan 20, 2016
Is that a figurative tone?
Or a literal translation??
I think so.
Vintage vinyl on Delmar St. Louis county.Good morning!
Got behind this vehicle the other day. Made me smile and want to ask him if he would like to see my chainsaw collection. [emoji16]![]()
Sent from my LE2117 using Tapatalk
Picking corn around here. Nobody's braggin!
Yields been all over the place round here..Picking corn around here. Nobody's braggin!
Well Carl...Do over and an aw chit:
Starter dog bolts on the Italian Alpina 70 are #12-24, not 5mm .8. (I helicoiled them when I stripped the holes using my flywheel puller. The flywheel is a Wico, made in USA. [emoji43][emoji94]
And, I discovered two rollers missing from the clutch drum bearing. [emoji90]
Levi said they started at 18% and worked their way down. Only after fixing the dryer...At the Seed chow last night, a friend said they ran 1280 acres that averaged 30% & made 214bu. acre. They hauled it to a feed yard & filled a pit. I believe fella he works for has around 12,000 acres. They were running 2 JD 780’s with 16 row heads and a new JD X9. Sean said they were running about 2-2.5mph with the 780’s, the X9 was running 5-5.5mph. Apparently these new X series are designed to run high moisture corn.
That's exactly what it is, Carl.Washing machine engine there, Steve?
