SteveSS
7:06 PM
I'm not one that normally takes pictures of my food, but I had to share this one with you guys. I stopped off at The Thirsty Hog Saloon in Fulton today for lunch and ordered the UFO platter. It's a fried pork tenderloin sandwich. Although you can't tell it's a sandwich because the bun is laid out and fully dressed, hidden beneath the giant slab of meat. There's a side of potato salad hiding under there as well. I ate half of it and I'm in the miserable stage of full right now. Highly recommended, but bring a helper or two if you plan to order one. This thing could've very easily made three regular sized sandwiches.
67L36Driver
7:06 PM
Revisited the 048 (money pit). Went thru the carb again as all it would do is half ass run on choke.
Everything looked good, fuel line, impulse, boot and carb has correct metering plate gasket. So, just to change it up I raised the metering lever a 1/64".
Holly smoke it runs and reacts to H & L jet adjustment.[emoji15]
I have a 3/8" X 25" bar and need to shorten the chain two drivers.
plcnut
Jesus is LORD
7:06 PM
Mansfield, Missouri
My little poulan carb started dumping fuel all over, as well as the primer bulb sprung a leak. I cleaned the carb twice and it still wouldn't tune. Finally put a Chinese carb on it yesterday and she is back to running normal. I put half a tank through it this afternoon doing some trimming. It's nice to have it going again.
Time's Standing Stihl
Below me...
8:06 PM
Central Iowa
Too damn hot out again today. I'm done with these 90s. Had the day off and played around.
Thought these were heavy....
Til I had to move these. Big ones got cut in half. I'm sure the ol' back will be sore tomorrow!
