67L36Driver
- 10:15 PM
- Jan 18, 2016
- Missouri
Corvair thermostats:
Both of these were new several years ago and very expensive.
One can see the one on the bottom has leaked just sitting on the shelf.
IIRC they are filled with alcohol or a fluid that expands to vapor at 180 degrees opening the air exhaust door.
Working ‘stats are a must in the winter or you will freeze your arse. Plus performance issues as there is no ‘heat riser’ for the carb’s.
