cobey
5:39 AM
Pittsburg, kansas
Ground chains and worked on saws all day. The new style stihl safety chains
With the square ish ramp suck ALOT
When you get down below 3/4 tooth.
I finally took the dremel and cut off
Wheel to them. I probably should have
Just cut the off, but i ground them
Down and set the height of them
With my roller guides raker gauge
On the hard setting . Have teeth ground
At 30 top and 55 side plate. Tested
2 20" chains on the Chinese 066
They feed harder than i thought they would
cobey
5:39 AM
Pittsburg, kansas
Any of the safety chain is a pita!
A few of the lo pro designs are not as bad
Due to short teeth, but you don't get
Many grindings on them before they are done
The safest chain is a sharp, well feeding chain, on a saw in good working condition, and with a good operator.
Bumps dont fix stupidity!
They just push harder
