9:49 PM
I saw this today. I do not understand how or why they would do this. Maybe it’s designed to leak or burn enough that the oils is kept fresh by adding. An thoughts? This is a pressure washer.
When it blows up you have to buy another.
Locust Cutter
Air Force Redneck
9:49 PM
KS
Carl, you're exactly right. They figured that a lot of the owners wouldn't take care of them, and did surveys and studies to get the data. So, they designed them where thy'll burn a small amount of oil constantly (we're back to two-stroke combustion, in a 4-stroke cycle) thus requiring you to fill it up every so often. Likely a lot of people won't do this either, and then they fry the bearings.
sawnami
10:49 PM
Springfield
We see that on a daily basis.
Cruze's are notorious for oil-related component failures. The EPA mandate for low petroleum product useage forces extended oil change intervals which is a big contributor to the failures. We've got a lady that puts over 120,000 miles a year on her Cruzes. She changes the oil every two weeks and because of her maintenance practices, her first Cruze made it to 480,000 miles before it was totaled in an accident.
teacherman
9:49 PM
NW Virginia
Fifth Ammiversary today. We just got back from dinner. Full, tired, but it was a good day. I’m getting
A 16’ utility trailer
With square side rails. Pick
It ip next week. Load Star brand .
Correction: Load Trail brand. Load Star makes really big ones. This one is rated for 5500 lb payload, rather than 55,000 lbs. LOL
teacherman
9:49 PM
NW Virginia
So are oil changes at 5K too far apart? (Mobil 1)
Workshop
9:49 PM
Nixa, Mo.
Oldest granddaughter, Tyra, 15, is into old vinyl albums. So, daughter and both granddaughters went to the other grandmas house this past week north of Chicago for spring break. Grandpa, now deceased, used to be a party DJ and had a lot of albums. Tyra came home with Sgt. Peppers Lonely Hearts Club Band. I'm sure some here remember that one, I grew up on it.
We're listening to it now on my stereo. (To give it justice). And I'm thinking.
Really?
Seriously?
I'm getting old, I don't remember it this way.
sawnami
10:49 PM
Springfield
Mobil 1 has pulled many an engineer's butt out of the fire. Engine oils see duty as coolant for turbocharger and supercharger systems, hydraulic oil for camshaft actuator systems and variable displacement engines, as well as lubricant. It sees a lot of wear and tear in what is considered normal use that previous oils never saw. Mobil 1 is usually the "go to" when it's found out the the oil formula engineered for the engine/transmission design turns out not to work so well.
Sent from my SM-T900 using Tapatalk
