- 11:27 AM
- Jan 28, 2016
- Dike, Iowa
I guess you are supposed to route the lines like this?
I did learn today that the electronic coil will fire with the points flywheel, I was bench testing a short block so I don't know if the timing is correct or not.
I also learned that in spite of testing bad (no continuity on the high tension lead) one coil made spark so I put wires on two more and again, no continuity in a test but they spark...
Now I have one with an oiler issue, I'll report more on that but even with the oil tank pressurized up to 7-8 PSI from an outside source there is no oil flow. Seems there is something I don't understand happening between the diaphragm/piston and the passage in the crankcase.
Mark
Super xl. Tough, rattly, and will probably outlive the both of us.What’d I get? View attachment 338302
Super XL-12, 58ccs of I'm going to run forever.What’d I get? View attachment 338302
The biggest problem can be the pump diaphragm itself. Replacements are not easy to come by. The DOT 3 treatment has revived a couple for me that probably would have been tossed by most guys. Takes a few days to work, but has proven to be a lasting remedy in the instances I've used it.
