- 1:50 AM
- Nov 16, 2022
- Long Beach, IN
Received a new G660 powerhead yesterday to use with a 36" Alaskan mill I'm setting up. Started right up, great throttle response. Ran perfect through several stop/start cycles, no leaks, all good. Serial number shows it was built November 2022.
Checked timing in stock form, got these numbers:
- Exhaust: 95
- Transfer: 117
- Intake: 82
Plan is to install a Cross cylinder kit and OEM piston bearing, should arrive next week. Some pictures of the as built saw, overall looks pretty good. NGK plug, all fasteners were tight with blue Loctite
Crankcase washout with mineral spirits showed no sign of metal.
Any other advice for this build?
- Exhaust: 95
- Transfer: 117
- Intake: 82
