HL Supply MS360 Warhawk cylinder kit test
wcorey
11:48 AM
ma usa
Is that maybe supposed to be 125 on the current transfer opening #?
I picked up a Warhawk 272 P&C on a recent HL deal just to fill in the order a bit.
Looks pretty good overall, will be grinding on it but it's clean enough that I'd run it as is.
wcorey
11:48 AM
ma usa
Wow, runs really good on such short blowdown.
I know some of the dual trans saws like the 046 do well at 14-16 but I've never seen one at 10.
I should have know it wasn't a typo, you certainly like to buck convention and push the envelope.
Was that an experiment or something you've been successful with before?
Chainsaw Jim
Con Artist LLC
8:48 AM
Springfield Oregon
I wrote all those other numbers down and I was going on memory with the last set. I believe I ended up with 15° BD. I need to set the degree wheel back up and check.
wcorey
11:48 AM
ma usa
At least you write down numbers.
One reason I don't do build threads is that I'm really bad with documenting things.
I never seem to remember that I'm not going to remember any of it for long, lol.
Chainsaw Jim
Con Artist LLC
8:48 AM
Springfield Oregon
I just degreed it through the spark plug hole and read it as 103-118-80. My starting point was to put it at 15° with the exhaust at 105. When I originally degreed it the ports weren't chamfered yet and I had a better view through the exhaust, so it may still be 105-120.
