Adamski
Plebus Splederns
- 6:55 AM
- May 3, 2017
- Essex, UK
This HD-12 on my 372 is giving me heart ache. It will not hold it's idle. One minute it dies from too low a mix the next time after a cut it makes the chain creep. I have tested every seal, gasket and case gasket. Their are no leaks. Any one else have an issue with these carbs. You only have to put the screwdriver ONTO the low adjust and it changes its speed. Idle does not change if I flip the saw etc. Chime the posts about an airleak.. I have tested everything. I am now blaming the carb..
