2strokejunkie
Active OPE Member
- 10:50 PM
- Mar 19, 2021
- Croatia
Well that is my suspicion that fuel is puddling.
But its interesting for me that the saw had nice throttle response and it would not load up if you would leave it for couple of minutes upright.
From my memory the L screw was maybe a little bit less than turn out.
Also i noticed these couple of times when i tried to start it it would do the choke gurgle and after that i would put in the run position and pull it couple of times and the saw would be flooded. Take the spark plug out clean it cycle a saw to clean the chamber put the plug in and the saw starts first pull but bogs like crazy because of probably excess fuel in the crankcase?
I went through 3 gasket kits(2 walbros,1 de errick) and only on the last walbro kit it got some will to start other two no chance.
