Grease Monkey Garage
Woodslasher
Teh debil
4:31 PM
Commiefornia
Quick question for y'all, the guy who'll be the main fabricator on this suggested a body swap as opposed to a transplant, what do y'all think? Ford body and a frame trim, or heart transplant?
davidwyby
Rural desert logging
4:31 PM
Extreme Southeast CA
F150 ? Frame and front axle not likely to hold up to the Cummins
davidwyby
4:31 PM
Boxed or channel frame? Pretty sure channel…no go for me. I’ve broken frame and body mounts on every 4x4 I’ve had…but I’m extra hard on stuff.
davidwyby
4:31 PM
2nd gen’s eat 70 rears…course your truck will be lighter and probably not towing as much.
If you use the divorced ford tcase you could use a deuce trans. Np205?
Mack 880
Happy to Stihl be Here
7:31 PM
SC
My RAM 3500 4x4 was very heavy on the front. Ate up the track bar and lower ball joints by 32,000 miles. That Cummins is a great engine, but OMG that thing is heavy. Also, with the Cummins won't you have to pull the cab anyway for install?
Woodslasher
Teh debil
4:31 PM
Commiefornia
Dana 24.
Negative based on what I've seen. Cab could remain solid based on seeing other folks swaps. Plus, I need to know firewall clearance when I bolt it up.
davidwyby
4:31 PM
Yup
The ford will be lighter overall but the engine will be hard on the ford
FergusonTO35
7:31 PM
Boonesborough, KY
How much bigger and heavier is a DT466 than a Cummins or Power Stroke? Has anybody ever put one in a pickup?
redline4
I'm huge in Japan
6:31 PM
Rosholt Wisconsin
I think it would be really kewl if you could get a Duramax in jade green with Detroit Diesel valve cover logos. If I ever own one I may do just that.
My brother in law was doing powder coating for a while and he did a bunch of different diesel engine parts in assorted colors for the bro-dozer bunch.
