Yukon Stihl
- 8:19 PM
- Jan 11, 2016
- Great White North
For me "Old stuff " means no stinking computers
I like your choice of alternators and the spacer is nice touch.Anything dual use is a bonus.Gotta go haul a tedder home in a few days....and can't stand this exhaust leak more than a few minutes. This is fun stuff.
View attachment 381294View attachment 381295
Good eye.I like your choice of alternators and the spacer is nice touch.Anything dual use is a bonus.
I like EFI and electronic ignition but nothing beyond that. Hell, I wish you could still get cable operated hvac controls!
I can see a cottage industry springing up to modify and disable ADAS similar to emissions delete on diesels. I've already deactivated many of the alarms and buzzers on our Odyssey.
I did the cylinder deactivation delete via unplugging the two connectors. Our oil consumption was due to leaks more than anything else, which have been fixed. It runs good so far.
Sweet! Where did he buy it at? Once in a great while ours does the random/multiple cylinder misfire thing for a few minutes and then straightens out on it's own. We only drive it on the weekends so I don't worry about it.
Love it.Spent some time working on my oldest running vehicle
1952 Power Glide
Its nice to work on something older than me.
I bought it a few years ago,a previous owner was restoring it when he ran out of time. A couple more stops before it crossed my path and i bought it.
Engine was rebuilt, new front end parts,new brakes,even the park brake worked.
Last year i got it going the gas tank had been dented by a forklift at one of its stops. I got the dents out soldered up the leaks.
Today i got a bunch of electrical stuff fixed.
Turn signals, starter button, horn.
I was able to make a good starter switch out of two. And i was able to repair the horn solenoid with a solder job.
Everything was built to be repaired back then.View attachment 381633View attachment 381634View attachment 381635
Ah, few things smell as good as a freshly painted engine on fire up.Got my Mercruiser engine about done.
The intake wound up being a good one (if you're into cast iron spread bore stuff)
Numbers match a early 70s Corvette intake. No EGR crap...
As to my little Mazda 626 which has lost A/C control. I'm about 95% sure it needs a pcm, but need to do alot more research before I pull the trigger. It doesn't help that my problem solving skills have degraded into frozen molasses. Right now I'm going to button her back up and drive it so I can fix other things, like finally correcting the leaky injector pump on the Fergie 165. What's funny is, this is the first car I've ever owned in my life that actually has good functional A/C. All my previous ones had dead R12 systems or didn't have it from the factory. So, I'm used to sweating it out with 255 air conditioning!
