FrankinShin build
Woodwackr
11:06 AM
ID
When I bought a bunch of old Shindaiwa parts a year ago mixed in the pile was an odd cylinder. It looks just like the 5-6 series (45, 49mm) but is a 51mm like the 7 series (750, 757), and is a closed port, unlike the 5/6 series. 7series are closed but completely different cylinder design.
It does not fit the 757 case but does fit the 575/680/695 case. Soooo.
I put a case together today and played with the 49 vs 51mm topends. The 757 51mm piston is a bit taller (2.5mm) than the 695s 49mm but that was easy to fix by slightly beveling the bottom corners of the 51mm piston skirt. Piston crowns are exactly the same. Squish for the 51mm, no gasket, is around .030.
Squish for the stock 695 topend....060+ . I know these are domed pistons but, sheesh.
The 51mm piston I'm using is trashed...just needed one for testing...I have nos.1000004947.jpg
If it works out I'll have a 695/757 hybrid...well, sort of, :p
Woodwackr
11:06 AM
ID
I still no idea what this cylinder came off of. I've checked IPLs dealer parts lists back to '89 and zip.
jacob j.
Only the weird
10:06 AM
Coastal Oregon
It may be something they didn't intend to release to the public but sent to a few select dealers.
Stihl did that in the 70's with their two-piece head for the 075 platform.
Woodwackr
11:06 AM
ID
Quite possible. The old dealer I got everything from was part of the Shindaiwa 757 prototype program…I have 4 of the original 757 prototypes called the 750 and a bunch of parts. None are in usable shape but I get a kick out of the 2-digit serial numbers :p I need to order some of the production parts just to see how well they match the prototype stuff. Winter projects.
When that program was starting, Stihl found out about it and asked Jim if he would try their new model out as well…the 044. Shindaiwa and Stihl paid for everything, saws, parts, labor, etc. most of Jim’s clients were pro fallers in northern ID. 12 dealers in the US took part.
At first I figured this cyl was off their larger cut-off saw but it isn’t.
It almost looks sleeved.
Woodwackr
11:06 AM
ID
So, from the Shindaiwa spec sheet, squish is supposed to be .075-.100 with a max of .18 😵‍💫 dang. Explains their compression #s of 140-156 with a 90 min.
OE gaskets are around .016
I wondered if I'd have plug clearance with a .030 squish...no problems.
I'm not sure how/if it will work, looking at the piston position in the exhaust as well as intake ports. I don't have a degree wheel but this is a good excuse to get one :p
Here are some pics of the 2 pistons...49mm 680/695 vs the 51mm 757. There is a different in the crown from tot of ring to edge. Will that be a problem? 51mm is about 3mm taller, overall and i beveled the bottom corners for. Learance. Any other skirt trimming suggested?1000004975.jpg1000004974.jpg
Woodwackr
11:06 AM
ID
Woodwackr
11:06 AM
ID
Was playing with this the other day. I noticed the Echo 7310 is a 51mm. Anyone have a junk one I could try out?
Or, can anyone get me all the dimensions and specs for that piston? Pin diameter, length, etc.
LRB has a flat top and a pop-up…will contact them for specs
Dukes has a flat top.
Shindaiwas are domed so that popup might work.
eric4
10:06 AM
Northern CA
Looks like a great project! I was wondering if I could Frankenshin my 577 with a 695 topend without any serious modification...
Woodwackr
11:06 AM
ID
the cases are the same so that shouldn't be a problem. you would just go from the 45mm to the 49. cranks are the same.
weird thing on these is the humongous amount of squish. I'm wondering about sending out a couple cylinders to be machined to get sq down to the low 20s from 70-100.
eric4
10:06 AM
Northern CA
If the base was cut that much, would it mess with spark plug clearance, ya think?
Woodwackr
11:06 AM
ID
That was my first thought but with the 757 piston there is just under .030 and plenty of plug clearance. No base gasket
