First time porting
merc_man
merc_man
3:46 PM
southern ontario
gonna try my first shot at porting. Whats a good start. I dont plan on changing timing would like to keep it simple. (For now)
I know it would be a little advance for me but wanna put a degree wheel on to get a better understanding of your numbers you guys talk about and what they mean.
Sent from my SGH-I747M using Tapatalk
merc_man
merc_man
3:46 PM
southern ontario
Oh ya forgot to mention i decided to try on the husky 353
lwhaples
3:46 PM
Vt
Maybe start with gasket delete and a muffler mod?
merc_man
merc_man
3:46 PM
southern ontario
Heres a pic of the port shapes
First is exhaust second is intake.
merc_man
merc_man
3:46 PM
southern ontario
Trying to figure my max width i could go on exhaust port. If bore is 1.774 i multiply it by 0.70 and get 1.2418.
So 1.2418 should be my max 70 percent. This dont mean i gotta try and go this wide.
The pic shows the stock port opening with a line on either side to show my max i could open it to.
merc_man
merc_man
3:46 PM
southern ontario
I shoot for 65% on work saws, 70% on race saws, if I can give it good shape and the skirt is wide enough
How do you determine if skirt is wide enough. if skirt not wide enough do you go by a percentage of the skirt
merc_man
merc_man
3:46 PM
southern ontario
Sorry for the dumb question and hope reusing your pic was ok.
So you measure 50 though from the straight part of piston(virticle edge) for work saw.
And also good to know a scribe will not hurt i used a pencil.
tree monkey
2:46 PM
wi
I also mark the port on my sanding mandrel, here you can see how much I changed the exhaust port
tree monkey
2:46 PM
wi
from the scribe line to the edge of the piston skirt, or 65% on a full circle piston
merc_man
merc_man
3:46 PM
southern ontario
that top ring on your piston, would the ring end be a problem. just curious if it would be too close to the edge of port opening and be a snag issue.
merc_man
merc_man
3:46 PM
southern ontario
Thought i would try to draw on paper what i plan to try and see what you all think.
I traced the port on paper and drew out about 64ish percent cylinder bore. Let me know what ya think of the shape. Would this work?
