stihl_head1982
Here long time
- 9:10 PM
- Dec 24, 2015
- USA
Collecting more good information!
I have the 660 kit with the MMWS cross cylinder and the 361 kit with a big bore kit with gasket delete. Both saws are around 195 psi and have advanced timing and muffler mods. Both saws are runners
Replaced the crap handle on the 660 with a wrap handle. The 361 will outcut a bunch of other guys 60cc saws with ease. Got a 25" bar on both the 361 is great for all but the big stuff.
Two more hickups, I guess its a common problem with the breakhandle interfering with the muffler, will have to clear that a bit.View attachment 275028
The clutch drum wont fit over the clutchbearing, too tight I will take some measure at work but I will turn the inside bearingsurface, make it a few thou bigger.
Also the clutch bearing roller retainer has a crack but I will try it anyway.
Yeah I'm going to order a couple keys in case I mess one up. Also going to get a few more muffler and base gaskets to keep on hand. Going to pull the cylinder after I get some run time on it and look everything over. It's been cold and snowy/rainy here so I haven't been able to get out and play.Mod the muffler and file the key to advance the timing. Makes a noricable difference.
