FarmerTec 660 "Kit" - What's the latest on quality?
Jason628
3:41 PM
Washington
Also. Anyone know if the handles are still junk? H&L has the full wrap on sale right now.
Jason628
3:41 PM
Washington
Just came in
Jason628
3:41 PM
Washington
Got the cases together. Had a ton of aluminum shavings inside the cases. Cleaned it all out with carb clean and wd-40 and compressed air. Paint on the inside didn't like the carb clean so I scraped it all off.
Jason628
3:41 PM
Washington
Well... I screwed up the clutch side seal trying to put it in. Got a little crooked and went too far. Going to have to wait for another set of seals. May use the one I popped out that came with it.. idk. Probably going to have to split the case to get the screwy one out.
Wonkydonkey
Plastic member
11:41 PM
Sussex, UK.
The clutch side seal is easily pulled out with a drywall screw.
Iirc tap the screw with a hammer to puncture the metal then screw it in a bit and pull on it with some mole grips or pliers.
I found making two holes first, opposite each other and having two screws in
Jason628
3:41 PM
Washington
Yeah I thought about that. Was worried I might run the screw through the nylon cage on the bearing but, probably will try that.
Jason628
3:41 PM
Washington
Got them in. Look relatively straight. I didn't have any 518 so I used motoseal on the outside and lubed the rubber part with wd.
Jason628
3:41 PM
Washington
Squish with farmertec piston is .029 with paper gasket. Piston hits the head with no gasket. One of the cylinder screws does not fit in the hole. Will have to clearance around it to get it to drop in.
