- 5:02 PM
- Dec 30, 2015
- Brewster, NY
Put the piston in the bore and mark where the skirts are with a sharpie.
Make the Exhaust as wide as possible, but do not go closer than .050 to the edge of the skirt.
Check the squish before you start. If you can go w/o a base gasket, bringing the Intake to 5/8" from the bottom will be about right. I also like to make that fairly wide and fairly flat. (you want to end up with .020 of squish). If you don't have a metal lathe, you can carefully sand the bottom of the jug (don't give it a slant) or put sand paper on a piston and sand the squish band.
Make sure you carefully bevel all ports so you don't hang any rings or scrape the piston skirts.
If you port the cylinder, I would also remove the baffle from the muffler and give it a timing advance (between .020 and .030 off the key).
It will run substantially better with those mods.
