EREANOR
Moparmyway
Its just a saw
5:09 AM
In a meeting
Class 2 :
Same rules as Class 1 with these exceptions.
Machine work is allowed to the squish band, cylinder base, and piston.
Finger ports, and/or bridge ports are allowed.
No two piece heads.
No external transfers.
OEM carbs are allowed as long as they are intended for the 1122 series. Carbs can be modded for flow, but a working choke is still required.
OEM intakes and impulse lines are allowed....but must be intended for the 1122 series. No intake blocks. No 084 intakes, etc.
Fuel filters can be gutted for more flow.
MaxFlow, or OEM air filters can be used, and covers are optional.
OEM coils and flywheels can be used.
I reserve the right to add to these rules if I forgot something, but the meat and potatoes will not change.
Edit: Just to clarify. No BB kits in this class.
5:09 AM
Pop up???
Fruecrue
certified hand catcher
5:09 AM
Alden NY
Perhaps an optical illusion, but it appears the squish band has a ring around the outside.
Not trying to call out your work, just an observe and report kind of thing. I'd rather see these saws destroyed by huge horsepower and torque stress than anything else.
GoBigBlue1984
Bluegrass Fart Knocker...
5:09 AM
Kentucky
Just the radius from his boring bar insert/tool. Shouldn't matter. Worse case scenario he'll chamfer the piston a tad.
Nice work Al.
jake wells
no longer here
4:09 AM
ky
Nah, a torquey Bruiser.
I believe we will be cutting 32" of material.
I don't have a 32" bar, so I'm hoping someone will be kind enough to lend me one when I'm there.
I also can't follow all the rules (I mean can't remember ever nuance) so I'm not sure what class I'll be in with a meteor piston.
you can borrow my chain and bar al its the least i can do for that fine husqvarny in my stable.
5:09 AM
Where is the GFY 36? Lol
hseII
Heef
5:09 AM
West Georgia
I'll spot you Doc.
5:09 AM
It's a fig newton of your imagination. No Ridge.
